Will this brake swap work? 73-up A arms + B body spindles,B body Rotors,Calipers work on Dart?
I guess you didn't believe me? lol
As long as the B spindles, rotors and calipers are 73+ you should be fine.
no , that was check if you can use the disc B body lower ball joint with your A body lower control arm :blob::bootysha:I did believe you but you are the one who told me to check. :tongue2:
