67Dart273
The "one wire" setups all do that, and I'm not saying I exactly agree with it, but the thing is, if the charging line is as big as it should be, "it will be fine." LOL.
Also bear in mind that as the battery comes up, and the charge rate reduces, there will be less drop. This apparently is "acceptable" because some modern trucks and tractors come this way from the factory!!
