72BBSwinger
In my experience a pressure plate is a pressure plate. I don't see why you would want a 10.5" disc with an 11" pressure plate though, I would just buy a matched clutch/pp kit and go.
...relocating the fricken starter pocket??
Questions I don't have an answer for, but may get your creative thoughts going.
1. Does the Hemi crank and the 3.7L V6 Jeep crank have the same flywheel bolt pattern? (they both have 8 bolts)
2. If so, can you use the 10.5" Jeep 3.7L flywheel, bellhousing and starter on the Hemi?
Just askin'... After all, I am a Junkyard Dawg....
Greg
Found the post by clair on why the 3.7L bellhousing didn't work...
I would like more information on why the stock starter can't engage the ring gear...
Per the post you linked from Clair - "Unfortunately, the flywheel ring gear on the 10.5" flywheel is located too far to the rear to engage the starter bendix. I haven't put juice to the starter yet, but it eyeballs like there will be little, if any, mesh between the bendix and ring gear."
Or maybe you are asking why the stock (not the 3.7L) starter wouldn't engage the ring gear?
Per the same post - "Obviously, you'll need a KJ starter as well, as all the other "typical" Mopar starters don't have the same locating ring on the snout, AND they're too deep as well."
Am I misunderstanding you? If so, I apologize.
You could always cut a starter pocket out of a 727 or 904 bellhousing and weld it into the Liberty bellhousing. Then you could use a Liberty bell and 130T flywheel. ;)
:angel9:
2002 Dodge 4.7 Flywheel - doesn't look like a dual mass to me, but I don't know if the picture matches reality.
LOL! SO... those creative juices are REALLY flowing now!![]()
So how would I approach this...
Over on www.car-part.com, if you do a search on 2003 Jeep Liberty - transmission bellhousing only- 3.7L, you'll find a couple for about 50 bucks. You can also find some 4.7 flywheels from the Durango and Liberty for cheap as well. Saw a 3.7L starter for 35 bucks. Could be if you contacted the vendors and requested a pic of the bellhousing and other items, you might get some more data points. Of course, the if you CAN use the 3.7 bellhousing, it might give a tad more room for headers.
....and.... I've found a REAL good source for pics and data and info is...... EBAY! Do searches on those items and you'll be able to connect to people that have them.
Just sayin...
Greg
"This ain't my first rodeo...."
I do know that some guys have swapped 5.7's in Dakotas and bolted them up to the original 4.7 trans.
Any more info on this? Were there bosses there to drill and tap or something? I don't remember any on mine, but I don't remember looking either.
I've planned to cut the starter pocket out and relocate it to match a 130T flywheel. I was going to drill a flat plate to match the pattern on 727 bellhousing and then use that to fix the starter pocket location before welding.
Really rather just drill some holes.
Can anyone confirm the 3.7L bellhousing is a passenger side starter?
Sorry, I miss your question. Lower hole was ok, I just tilted upper part closer and made a new hole. There was enough material, but no specific boss for that. And the starter pocket "nose guide" needed some trimming inside the bell, if I remember right. Which is no problem, cause RAM MP starters bendix gear is supported on its own.
Surely it would be easier to go with 143t with Dakota bell, but I got hemi alu-flywheel so cheap that I went this way.
As a pilot bearing, I was using `90-up mopar pilot bearing sleeve, and just opened the center hole for Toyota bearing, and didnt push it too deep, so the input shaft tip slide good amount in.
Hi Jousi, did you experience also shifting problems under full load acceleration like on the track?Very good project you have indeed. Here in Europe the only good, and somehow available (thus expensive of course) option from Aisin trannies was that R154,but those start to be under the rock by now, very popular on drifting.
Good to see how you proceed, best of luck to your project!
I found several picture that led me to believe it is a drivers side mount, but didn't post anything because I wasn't sure I wasn't being tricked.
I can try and find them again tomorrow and post one or two, if you want. Just didn't want to lead anyone down the wrong path.
This pic you've previously posted IS a Jeep Liberty 3.7L V6 bellhousing. I can tell because it is less "phat" than the Dakota 3.9L V6 bellhousing. And yes, the starter is on the DRIVERS side.
http://www.factorychryslerparts.com...iveline=7463&ukey_trimlevel=18760&modelYear=0
Greg
Can't lead anyone astray when nobody is sure! I won't turn down any help.
Greg, hate to disappoint but you're looking at the diagram for an NSG370 6-speed 3.7L from 2009. Totally diffetent from the 01-04 bellhousings listed in your original guide. As for the bellhousing above, until we can find a visual representation of the 3.7L, I'm inclined to continue assuming that's a 3.9L bell.
I think Greg is right. I found the same picture online and read what the guy was saying when he posted it, and per my understanding that would be a 3.7L bellhousing.
Here is the thread I found it in.
Also, I noticed that the above pictured one doesn't have a slot for the crank sensor, while the 3.9 Dakota one's do, in addition to differences in where the vent is.
The thing that confuses me is, Clair made it sound like there are no provisions for mounting a starter, while I see bosses there. I suspect they aren't tapped and are oversized, but there is still a flange and holes. He also said it wasn't deep enough, but that could be fix with a dremel or something. Is it not possible that there is enough meat there to use the holes and bolt up a standard starter? Maybe a helicoil or something would bring it down to the right sizes, or build a plate that has studs or something that fits on from the back side? Oh wait, I'm assuming the bolt pattern would be the same, aren't I.
I'd sure like to see those picture Clair sent you, Greg. I'd be willing to put them on my photobucket account and link them here, if there were no issues.
Compared pictures of a Liberty starter to a Dakota one on RockAuto, and I don't think things will line up. Darn.
Here's the pictures Greg has:
Greg
