1966 valiant
Active Member
First I would like to say hello to everyone. I just signed on to this website. Here is my problem. I picked my car up from storage after a 7 month winter here in cleveland ohio. My car fired right up and drove just fine. I got to my driveway and tried to restart and had nothing. The radio does come on when I turn the key either way. I found I could jump the starter solenoid to start the car. So I put a new one in and had the same problem. I tried 3 different ones with the same results. Put in a ballist resistor just to see if it would make a difference it did not. All contacts seem to be good. I pretty much suck at electrical problems. But I have narrowed it down to the ignition switch or the neutral safety switch but I don't know how to check these problems. I did try to start the car by moving the shifter around. It is a 904 automatic on the floor.Any thoughts on this would greatly help. Thanks in advance.
