j par
Well-hung Member
He put dual quads on and dropped a 1/2 second, so now he has etched it in stone that his 318 needs about 1000 cfm's..... to run a best of 13.7 !!!
P.S. I bet the post above that saw the 318 go 11.70's had a single four barrel on it.... Just a bet!Did I mention I saw a 340 go 10.90's with a TQ on a factory cast intake?? In an all steel '71 Demon---all motor? no boost or NOS?
I very much believe my LD4B with the center cut out for single plane would be faster. That setup got me a 15.4on cool eveevening. Put the dual quad tunnel ram on and went on a hot afternoon two weeks later and got a 14.8- first pass then put on slicks and got a 14.2 @96mph. Then I put the battery in the back, took out the heater/ ac from under the dash, gutted the doors 52 lbs each! , and put a little electric motor to run the water pump and fan. Went back out- first pass 13.7 @98mph.
i would like to run a six race series in Woodburn oregon 60 miles from my home next year called "the hole in the hood" series. Again the dual quad tunnel ram and pistol grip 4-speed is something that I must work with because it's - it's - it's cool as? Uncomparable !! It is the coolest thing ever! !!!!
I know a single playing is going to be faster ultimately but I want a dual quad tunnel ram and pistol grip 4-speed! !!!
Dose anybody have some suggestions for my 318 to work with this situation this over carbureted mess that I must have?:banghead:
