RAMCTD2003
340dart
I am going to be installing a 360 magnum block/LA heads, but using a magnum cam.
My question is what are you guys running for an electric fuel pump since I don't have a fuel pump eccentric? Do you run a return fuel line? I am installing this in my 74 dart sport.
There is a stock line that runs from the charcoal canister to the tank. Can I use it as a return line? I would like a fuel pump that is on the quieter side if possible.
