Post your wheel and tire combos.
My new rear magnums to match my fronts. 15x12 8"BS on 315/60/15
attachment.php
Man! I love those.....Big bucks!!!
attachment.php
Thanks!! A lot. If you think they are pricey wheels in the U.S. You should see what it's like in Canada!!!! :banghead:
But I just had to have them.
15x12 on 315s. 8" backspace. Just some info if anyone was interested in the set up.
73 Duster, fronts are 15 x 4 with 2.125 bs running 175 65 15, rears 15 x 8 with 4"bs running 255 60 15.
American Racing Torque Trust D gray matte finish, running Wilwoods front, 8 3/4 drums on the rear with no other suspension mods.
Nice. We need the specs.
Fronts: 15x4.5 2.0" BS 205/75-15 tires (see note*)
Rears: 15x10 4.5" BS 315/60-15 M/T Drag Radials
* The 205/75 tires won't fit on a Duster without stretched fender
openings but a 205/70 is about perfect for an unmodified Duster.
Are you running the stock length A body housing in there?
Time for another dumb back spacing question!
I have a 1973 swinger with slicks on it currently and need to get a set of rims to mount my street tires. The street tires are 235s and from what I have gathered from reading nearly every post on this thread is that I am going to want 4.5 back spacing to give them plenty of room. Does this sound correct?
No. The car is back-halved with the frame rails over an inch a side narrower than the
stock rails. large wheel tubs and 4-link. Don't know the housing width but Denny would.
What wheels are those?
I've seen many back half jobs and I have seen maybe a handful that look as clean and as tight as this job. Kudos to the builder
