Post your wheel and tire combos.
edited for dupe post and better info
1971 Demon
18X10.5 rear 275/35-18 Michelin pilot supersports
18X9.5 front 245/40-18 Michelin pilot supersports
Couple little tweaks with other additions and she will be back on her feet and I will add a few more.
Nice! :thumbup:
Any modifications to your suspension? What backspace #s are you running?
Nice! :thumbup:
Only 3/8" trimmed from the fender lip, springs in stock position, 1" spacer/adapter (temporary until I install a full width 8.8 ). I believe the wheels are 6.36BS and 22mm offset in the rear and the fronts are 5.95BS and 24mm offset. The rear tire is 3/8" from the spring and 7/16" from the fender lip. I'm very surprised by the ampunt of space I have given the springs have not been moved in and there is still an inch of fender lip. Also, there is currently a 7.25 rear end in the car.
Nice! Yeah the stock Demon/Duster wheelhouses will take some pretty decent sized tires with the right offset.
Do you still have the stock UCA's on the front? I had to go with tubular UCA's with mine because the rims would touch the UCA's at full suspension droop and steering lock.
I won't know for sure til I get the front lowered to where I want it but it looks like there will be more than enough room
1971 dodge dart swinger
Small bolt pattern
14×6 205/70 front factory 340 wheels
15×7 245/60 wheels vintiques mopar steel. 4" backspacing on the rear
On the ground. PST 1.03 bars are ordered to get that front end down.
205/70 R14 all around
BFG redline
Finally got out for a ride. Needs an alignment now really bad lol
can anyone help me with some of the measurements for fitting 16" wide on a '73 duster? i love all these wide tires lol
Rear 325/50/15 MT ET STreet radials, 10 inch wheel with 4 1/2 back space.
Front MT 6 x 15 skinnier on 4 inch wheel with 1 3/4 backspace
Mini tubbed with RMS Street Lynks 4 link.
Front 20x9 235/35. Rear 22x10 255/30
:prayer:
That looks AMAZING. That is the look i'd like to achieve with my car.... I ran through your build thread, but didn't look too deep into it right now... Bet that took a whole lot of work to fit?
17x8's front/rear 245/50-17 rear and 235/45-17 front. Post '74 dart/duster disc brakes front and 7 1/4 rear end.
Pretty cool... was wondering what the Year One 17" rally wheels would look like on an A-body. Do you have any more pictures of your car with the drag lites... It looks pretty killer in your avatar picture!
:prayer:
Thank you! Only mods needed are offsetting leaf springs inboard about an inch, grind the fender lips flush to the wheel wells, and appropriate rear wheel spacers.
i am running 195/60 r15's on my 67 valiant. The original tires were 165/80r 13's over all height difference is 1"
