skokz
Im not sure if this is in the right section. It is a c-body question but not a member on that forum. Signed up over there but cant post over there yet.
Does anyone know if a 62 poly 318 will fit in a 68 fury that had a 318?
From what I can see looks like the bellhousing are the same.
The distributors will change out too.
My biggest concern is will it fit since they are wider and fit with the steering linkage.
Should it have the same oil pan setup as the fury if it came out of a car?
Found one for sale trying to get as much info as can before drive two hours to go look at it.
Thanks.
Thanks.
