Wilwood disc brake install tips?
cooooledart
California
About to start installing the front disc kit from wilwood. This is for the 10 inch drum spindle. It seems pretty straight forward. Anyone done this before? Any tips or things to be aware of?
I did mine recently was all straightforward although mine was already disc to start with if you have to complete kit give it a read good read through of the instructions and I dry fitted everything 1st only loose tho just so I knew I was happy with it before applying loctite.
I've put on three kits. Pretty straight forward, just follow the directions. you'll need to shim to center the caliper with supplied washers, but that's pretty easy. Check to make sure your brake lines are correct (length) for your application. It does take a bit to get the calipers bleed completely, but they are nice kits
