HDK on a early A
prrc
Indiana
Just thought I would share my install pictures. Some may have all ready seen these in my build thread pro touring 10k. Let me first say that Dennys HDK suspension is top quality. I build these car for a living and I install a lot of aftermarket suspensions. The HDK is very nice. you wont be disappointed. So here is my set up . 2" wilwood pro drop spindles. wilwood 13" rotors with 6 piston radial mount calipers. Wheels on the front are 18x8 6" B/S with a 235/40/18 tire 25.4 over all diameter. wheel and tire set right in the center of the wheel well. front crade sets at 6 inchs off the ground and front fender at its lowers point is right at 5" . The pixctures are set at ride weight. hope this helps some one considering the HDK set up.
Unbelievably nice placement for an 18x8 wheel on this little car. The wheel design itself is also a personal favorite. Can't wait to see updated photos as this build progresses.
The big brakes should make it quite a driver. Obviously you know what you are doing.
How much in parts did it end up costing? (brakes, rack, spindles, plus the $2800 for the subframe)
I'd love to do this to mine. Would make the big block a much easier fit as well.
My stance on suspension is unless you intend to race hard in corners, why waist money on these overpriced suspensions parts..
My parts cost will be some what less than the average guy can buy for. I own a speed shop/ Fabrication shop in Indy. So I'm not sure on realistic price for parts
Who makes those hoops the upper shock mount welds to the frame? I need a set as I gutted my inner fender...
The hoops are part of the HDK kit. look up hemidenny I'm sure he will sell you a set.
