63-66 lets see your wheels...
My 66 when I brought it home.
15x8 rallies with 275's didn't like the look so went with the steel rim.
this is my 64 dart. i am still working on the front suspension the rear wheels are not on the car yet. i still need to install my rear axle. 17x7 front and 17x8 rear. 5x4.5 lug.
Here is my 66 when I bought it - with white walls and poverty caps
Changed to 14x5.5 and running 205/70s all around and dressed up with Belvedere spinner caps
Jw97neon, I can't help but think I've seen those wheels on a '64 Dart before...
Mopar 14"x5.5" Steelies. BFG 215/70-14 tires. :burnout:
I have always been a big fan of RALLY'S. The Scamp will have RALLY'S on it also, only with the acorn center caps.
First: Cragars. Second: Monocoque custom 15" front and rear SBP. Same car.
Here is my current set up Showtime, 17X8 on the rear and 17X7 on the front. Believe it or not still small bolt pattern.
Here is my 65 Cuda with 17's all round, 275's 40 17's on the rear rims and are +24mm with a 5.95 back space. On the front I have 225 45 17's. Rear rims are 17 X 9, and front 17 X 8 these are BBP. I bought them from American muscle, I'm running an 8 3/4 rear with Yukon axles with wildwood disc brakes and green wheel bearings. This is in the stock wheel well with a 3" offset spring kit.
18x8 and 18x10
Does anyone have 4 14x7 steel wheels for a 63 Signet 200? I would like to step up from the 13", but want to use the same hubcaps. Does anyone know if this will work?
2006 Mustang GT 18 x 8.5 polished aluminum five spoke.
heres what I just put on my Dart yesterday
14x4's with 195/70's and 70's dog dishes......much better than the way to baby blue 13's
Oh, also fishing for comments on the wagon roof rack sitting on it!
I have a roof rack that looks a lot like that. I took off of a 50 New Yorker sedan years ago but don't think it was correct for it. Believe it was after market, mine did not have any mopar emblems cast in the bottom of the stanchions.
