schmitt Well-Known Member Joined Feb 17, 2015 Messages 295 Reaction score 50 Location WI Feb 19, 2016 #1 Guys is there a better solution to my problem? Fuel elbow is hitting the coil mount bracket. I could add a carb spacer and clear it I guess? Where do I mount my coil then though? Attachments image.jpg 17.8 KB · Views: 261
schmitt Well-Known Member Joined Feb 17, 2015 Messages 295 Reaction score 50 Location WI Feb 19, 2016 #2 Pic Attachments image.jpg 18.2 KB · Views: 250
ScampMike Despicable Damn Yankee Joined Oct 26, 2015 Messages 33,853 Reaction score 8,995 Location all Mopar driveway Feb 19, 2016 #3 I've seen a lot of cars with the coil mounted inside the car.. mine is on the floor on top of the trans tunnel and about 4" from the firewall
D Dodgeguy101 "Motor Whisperer" Joined Jan 3, 2010 Messages 56 Reaction score 20 Location MD Feb 19, 2016 #4 Not sure it will give you enough room for the coil, but one of the fitting companies make a shorter fitting to go into the carb. I think I saw it in Jegs catalog.
I IQ52 Well-Known Member Joined Jul 30, 2011 Messages 2,870 Reaction score 3,071 Location Idaho Feb 19, 2016 #5 ? http://www.summitracing.com/parts/fra-491952/overview/
schmitt Well-Known Member Joined Feb 17, 2015 Messages 295 Reaction score 50 Location WI Feb 19, 2016 #6 Thanks fellas! I'm going to see if I can bring it up more using that fitting you guys posted without having it hit the linkage on the carb then. Would running a carb spacer hurt or be beneficial?
schmitt Well-Known Member Joined Feb 17, 2015 Messages 295 Reaction score 50 Location WI Feb 19, 2016 #7 Can't bring the line up anymore without hitting the linkage of the carb. Carb spacer looks to be my only option? Attachments image.jpg 17.5 KB · Views: 216
Woods74 Broke Senior Joined Aug 21, 2010 Messages 6,003 Reaction score 484 Location Seattle, WA Feb 19, 2016 #8 schmitt said: Thanks fellas! I'm going to see if I can bring it up more using that fitting you guys posted without having it hit the linkage on the carb then. Would running a carb spacer hurt or be beneficial? Click to expand... 1/2" spacer helps with mixture in un-equal plenum intakes like the air-gap. Unless you have the center intake milled down, watch this video: [ame="https://www.youtube.com/watch?v=Bmj48i_v6-8"]Weiand Vs Edelbrach intake manifold dyno comparison - YouTube[/ame]
Dubob FABO Gold Member FABO Gold Member Joined Oct 28, 2011 Messages 1,409 Reaction score 741 Location Ohio Feb 19, 2016 #9 I used a vertical mount for the coil. http://www.manciniracing.com/corebrunmo.html My RPM intake has bosses on drivers side and passenger. Attachments image.jpg 17.8 KB · Views: 179
akrateffil FABO Gold Member FABO Gold Member Joined Sep 11, 2004 Messages 213 Reaction score 83 Location Effingham, Illinois Feb 20, 2016 #10 I mounted my coil on the fire wall. Attachments IMG_0007.jpg 53.2 KB · Views: 186
zac_F71 Well-Known Member Joined May 4, 2011 Messages 1,367 Reaction score 100 Location Clitherall MN 56524 Feb 21, 2016 #11 Mounted mine on the fender well.. The fuel line - I plan to do a setup like my old fox body had - pictured below
