Just some teaser pics of test fitting the engine to see what needs cut. As it looks, if I notch the pan a bit and possibly cut a bit out of the K-frame and then re-weld it with more of a square in it instead of the rounded section if need be. Then remove both of the motor mounts, it should fit pretty easily. I can't use the CAC from the truck since it is to wide and won't drop between the frame rails, so it won't drop down low enough to clear the hood. I also think I will not be able to use the hydro boost for my brakes. The P-pump is just to big. I wish I would been able to find the rotary VE pump that I wanted, because I think it would have more room, but I guess I will just have to strong leg it.
