coalman Well-Known Member Joined Aug 6, 2015 Messages 1,223 Reaction score 135 Location Texas May 13, 2016 #1 How many different size return hose's are there, for early Mopar power steering installations?? Thanks!!
65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 13,693 Reaction score 4,536 Location Strasburg, VA May 13, 2016 #2 coalman said: How many different size return hose's are there, for early Mopar power steering installations?? Thanks!! Click to expand... i believe up through 66 it is a 5/8in hose; after that they went to 3/8 in
coalman Well-Known Member Joined Aug 6, 2015 Messages 1,223 Reaction score 135 Location Texas May 13, 2016 #3 Thanks a bunch, the one I have is 5/8" coming off steering box fitting size outside diameter. I am doing a Bergman/Borgeson conversion and the new return tube is 3/8". The pressure side is fine, any suggestions??? Thanks again
halifaxhops It's going to get stupid around here! FABO Gold Member Joined Jan 20, 2014 Messages 87,025 Reaction score 67,318 Location Hoppyworld, PA May 13, 2016 #4 Go to a equipment shop or ag equipment shop they should be able to put a adapter between the two sizes.
65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 13,693 Reaction score 4,536 Location Strasburg, VA May 13, 2016 #5 If the adapter fitting (5/8 to 3/8) won't work, a later pump could be found.
