[FOR SALE] Duster Parts - Power Steering / Dana 60 axles / U bolts
tnts72
Illinois
Rating - 0%
0   0   0
Have a power steering pump / box / mounting brackets - can include a pitman arm, but it is the top down version which came on my manual box. Power box had a little slop, probably would need rebuilt if someone wanted to put it back into service. Pump worked fine, no noises or leaks - does have two factory shim washers in the pressure valve - pump it down mod. made the slop a bit more noticeable, which is why I went manual steering.
$150 come and pick it up will be a heavy one to ship!
Power Steering column to box coupler - stamped metal cover is a bit mangled but useable and the springwire (Ebay) keeps everything in place. Includes everything pictured
$40 shipped
U bolts from ESPO, had to get a longer set when I installed the lowering blocks, few nicks and dings from installation and removal - can run a die over them before shipping if buyer would like. Nuts and washers included.
$20 shipped
Dana 60 axles 29-5/8" long I believe, 5 on 5 pattern 30 spline. Could be a set to get cut down and resplined if narrowing a 8 3/4 or Dana 60.
$100 pick them up
Mini starter / Black steering wheel are about the only items I would be interested in trading for at this time.
Or a Plymouth grille emblem - yeah right I know!
I have some more parts I will add to the thread as I go along...
SBP wheels and tires
$300 pick up preferred
215/60/14 on the American Racing wheels
2 - 5 on 4 steelies included 185/75/14
5 on 4" 1.25" thick spacers $75
throttle bracket $30 - missing kickdown rod
Column shifter linkage worn, but worked $20
Evaporation canister mount $20
Pitman arm $20
Automatic shifter with roll pin and spring $20
7 1/4" rearend shock plates $40 pretty rusty, but useable
All small part prices are obo and include shipping. If someone wants the rims shipped pm me and we can figure out a deal.
Trades: black steering wheel, mini starter, 360 manifolds, cylinder heads...
9" front drums with upper control arms. Complete as removed, would need the control arm rebuilt before reinstallation - brakes were functional when removed.
$100 come and pick them up.
Power column coupler sold. Have a guy interested in trading for the 14" steelies. Make some offers
Pitman arm, Drag link, Idler arm?
How much?
I traded the Pitman arm Saturday to a local guy for a set of bare 360 heads. Forgot it was listed, sorry about that. I do not have an extra idler arm or center link. Pitman arm was the top down version - wrong for our 72, l pulled it from the manual box whe I put it in.
