SWED67barracuda
Hi Gals a`n Pals. Does anyone know where to find either the lockstrip only or both the weather strip and lockstrip for a 67 Barracuda .Front and rear window. greateful for help. Ubbe.
Ubbe! There is a great supplier that sell rolls on Ebay for 1967 A-bodies cars. Good luck with your car.Hi Gals a`n Pals. Does anyone know where to find either the lockstrip only or both the weather strip and lockstrip for a 67 Barracuda .Front and rear window. greateful for help. Ubbe.
Hi Steve.I`ll check out the thread.It`s a notchback.There are some photos in the Photo garage forum. Thanks for info.Ubbe.Ubbe do a search for a thread I started. Mylar lockstrip. I have a 67 cuda as well and the stuff is pricey.
Precision is the only company that makes it.
Notchback or fastback?
Cheers
Steve
Does the lockstrip serve a purpose? One of my cars has it stored in the trunk. Thank you.
I stock the gaskets and lock strip. They are rather pricey, but they are correct and made by Precision Gaskets and have not heard any complaints from anyone that has installed them. They are a 67 specific part so you have to have the correct gasket to use the correct insert. If you have more questions, drop me a message.
Ok , this is not the quickest reply but anyway . I need lockstrip for the windshield and have the original gasket , how much are they , and are the corners included .Regards Ubbe .I stock the gaskets and lock strip. They are rather pricey, but they are correct and made by Precision Gaskets and have not heard any complaints from anyone that has installed them. They are a 67 specific part so you have to have the correct gasket to use the correct insert. If you have more questions, drop me a message.
I have the outer two lockstrips for your car if you are interested!
Yes Steve , front it is , we`ll se what happens . Regards Ubbe.Ulf I might be interested if they are available?
Im assuming you are talking front?
Cheers
Steve
