rustycowll69
so expect even more smoke when it finally starts. You might want to plug in a big fan in front of the car, it will clear out all the smoke so you don't set off all the smoke detectors in the house and garage, and help cool the engine until you get the coolant levels sorted out.Yep, it spurted all over the headers! I had the front end jacked up to make sure the oil filter adapter wasnt leaking. Made the angles weird and it flowed from the rear rocker to the edge of the block and down. Ohh well.
