Fresh Startup Procedure.
Discussion in 'Small Block Mopar Engine' started by WSUTARD, Apr 20, 2017.
  1. WSUTARD
    WSUTARD FABO Gold Member FABO Gold Member
    592
    73
    Jul 13, 2016
    Seattle, WA
    Local Time:
    2:51 PM
    Would love opinions on the startup procedure for a "sort of fresh" build. Details are, I pulled the engine just over a month ago. Changed the head gaskets and the cam/lifters. It has been sitting without oil for this entire time. I put plenty of cam lub on the cam when I installed it and two weeks later when I finally put the intake on. I'm also installing a recored radiator.
    Here is what I plan to do based on my reading.
    1. Fill with comp cams break in oil
    2. Pull plugs and squirt some break in oil in each cylinder.
    3. Pull valve covers to ensure oil is flowing during priming.
    4. Pull distributor and use a priming rod and a drill to prime the engine with oil.
    5. Hand crank engine while priming.
    6. Once I see oil dripping from the rockers on each side I will stop priming.
    7. Re install plugs and valve covers.
    8. Hand crank engine to TDC (0 degrees on my dampener)
    9. Reset distributor gear and distributor to point at #1 cylinder and #1 cap plug (hoping to get 0 advance or retard)
    10. Fire the engine...(or at least try)
    11. Check for leaks of stuff.
    12. Once engine is running, set timing advance to 10 degrees.
    13. Start cam break in (2200-2500 RPM for 30 minutes. Oscillating through the RPM range.
    Thoughts?
  2. yellow rose
    yellow rose Doctor of Thinkology.
    9,300
    5568
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    2:51 PM
    Skip number 2. I can't think of a reason to add a detonation maker in a new cylinder.
    On number 8, set the crank to 36-40* BTDC and make the rotor line up with number 1 on the cap at FULL ADVANCE. New engines do NOT like retarded timing on the start. It will make a butt load of heat in the exhaust. I have seen guys stick exhaust valves that had plenty of clearance with retarded timing. I'd rather see 50* than what you want to do.
    Between 9 and 10 make sure the carb has fuel in it. Don't crank the starter to get fuel in the carb. If it's a Holley, pull the plug out of the fuel bowl and squirt fuel slowly down the vent until you see fuel in the bowls. If it's a Carter/Edelbrock I forget where the vent are.
    12. When the engine gets 140 degrees of water temp, pull the total back to 35-36*.
    You should be golden.
    • Like Like x 1
    • Agree Agree x 1
    • WSUTARD
      592
      73
      Jul 13, 2016
      Seattle, WA
      Local Time:
      2:51 PM
      I would love to not have to pull the plugs!
      When you say at "FULL ADVANCE" what do you mean?
    • krazykuda
      krazykuda FABO Gold Member FABO Gold Member Technical Editor
      39,307
      6421
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      4:51 PM
      When you first start the engine, make sure you get good oil pressure...
      check underneath for any leaks and address as needed...
      Then get it to idle until it's warm, then set timing to 34°-36° at 2000-2500 and start the cam break in....
      Keep an eye on temp gauge during cam break in to make sure you don't run too hot and over heat....
      • Agree Agree x 1
      • 440DART1970
        440DART1970 1970 Dart 446ci Swinger
        588
        148
        Nov 9, 2016
        NJ
        View My Photos
        Local Time:
        5:51 PM
        Follow
      • nm9stheham
        nm9stheham Well-Known Member
        7,996
        1207
        Dec 20, 2013
        Waynesboro, VA
        Local Time:
        5:51 PM
        You are a good learner, Wsutard.....
        Pull the plugs early on or you'll be fighting compression as you hand turn the crank while priming. You have to turn the crank about 10-15 degrees at a time and let it set for several seconds while priming to wait and see if you the oil coming up to the rockers; it takes a while once the cam is aligned.
        In step 8, don't put the valve covers on until after this step is done; when you put the crank at TDC, either #1 or #6 can be at the firing point. You have to look to see which of these 2 cylinders' valves are slightly open, and then line up the spark rotor on the OTHER cylinder. One will be at overlap at the end of the exhaust stroke and the other will be ready to fire at the end of the compression stroke.
        Then turn the crank to 10 degrees BTDC (10 degrees of ignition advance) and then adjust the distributor so that the trigger tooth is lined up at the small steel insert in the reluctor. You'll be close to on time with this technique.
        Step 9A: Go the bathroom
        Step 9B: Take a deep breath (after leaving the bathroom...). Then proceed to fire it up.
        • Agree Agree x 2
        • Like Like x 1
        • Marcohotrod
          Marcohotrod Well-Known Member
          1,748
          271
          Mar 21, 2015
          Massachusetts
          Local Time:
          5:51 PM
          no need to pull 8 spark plugs, just remove # 1 to set the crank at 35-40 degrees before top dead center on the compression stroke (thumb over the hole to feel) to install distrib with rotor pointing to the #1 wire on the cap. remove distrib and oil pump driveshaft to spin oil pump. pour gas into carb bowls. Do not idle to warm up! pump carb 3 times and hold throttle open about 1/4 and bring to 2000-2500 rpm. leave radiator cap off, to add water sooner rather than later
        • mario03srt
          mario03srt FABO Gold Member FABO Gold Member
          432
          83
          Apr 12, 2015
          Amelia Oh
          Local Time:
          5:51 PM
          All,
          I'm firing my newly rebuilt 360 tomorrow also, rain permitting. Does it matter if the oil pump prime is ran cw or ccw? All new components firing up for the first time. Engine, HEi Ign, FiTech, Elec Fans....Wish me luck everything has been checked and double checked and 12v power to everything. FiTech primes and give an initial squirt, controller is programmed. Woo Hoo!
          Wish me Luck! It's been a journey for sure!
          Thanks,
          Marion
          • Like Like x 2
          • rustycowll69
            rustycowll69 Well-Known Member
            932
            259
            Feb 19, 2016
            Pacific northwest
            Local Time:
            2:51 PM
            you don't need to use a drill motor to prime the engine, a 1/4" speed handle works just fine, too. It will be very apparent when the oil passages line up, because you'll hear air being forced out of the oil passages, especially if you prime it by hand. If you choose to squirt oil in the cylinders, I just use a few DROPS of 2 cycle oil.
          • rustycowll69
            932
            259
            Feb 19, 2016
            Pacific northwest
            Local Time:
            2:51 PM
            yes, you must run in the correct rotation direction. Same as dist. rotation. For SB, it's CW.
            • Thanks! Thanks! x 1
            • Agree Agree x 1
            • mario03srt
              432
              83
              Apr 12, 2015
              Amelia Oh
              Local Time:
              5:51 PM
              KEWL, make sense...but I take nothing for granted, and this sight has all the inside scoop! I made need some valium!
              Marion
            • rustycowll69
              932
              259
              Feb 19, 2016
              Pacific northwest
              Local Time:
              2:51 PM
              something I've done in the past, is screw a cheap mech oil pressure gauge directly into the oil press sender hole by the dist. to make sure all the gallery plugs are in and oil pressure is as expected.
              • Agree Agree x 1
              • mario03srt
                432
                83
                Apr 12, 2015
                Amelia Oh
                Local Time:
                5:51 PM
                rusty,
                I have a mech oil gage sourced right from there! Its in the car but should be the same
                Marion
              • jbc426
                jbc426 Well-Known Member
                1,345
                288
                May 30, 2007
                West Coast
                Local Time:
                2:51 PM
                It is exciting, and stressful, but there is some good advice above. I like to have a fan blowing through the radiator. Setting the timing at 10 to 15 initial is good too. I also use a handheld lazer temp gun to verify temps, opening of the thermostat, even exhaust temp etc. Make sure nothing is too close to the exhaust.
                When spinning the oil pump, you will know if it's spinning in the right direction by comparing the rotation to your firing order 1-8-4-3-6-5-7-2. It will also blow air into your sump if spun the wrong way, and you can hear that.
                Have a helper assist you with checking under the car for leaks and standing by with the towel, hose and extinguisher for a fuel fire.
                Speaking of hearing, I like to start my motors with full exhaust, so I can hear the motor noise easier.
                Make sure to have a garden hose with nozzle turned on and at hand, some good sized towels for carb fires and also a quality fire extinguisher as a last resort. It's hard to clean up the residue if you don't have a Halon extinguisher.
                • Agree Agree x 1
                • WSUTARD
                  592
                  73
                  Jul 13, 2016
                  Seattle, WA
                  Local Time:
                  2:51 PM
                  Great advice everyone. I have a question for ensuring I am on #1 fire stroke. When I put in the new timing chain I ensured that #1 Compression TDC was aligned with the 0 on my dampener. It is my assumption that every time the dampener hits 0 that #1 is TDC on compression. Is this this case?
                • rustycowll69
                  932
                  259
                  Feb 19, 2016
                  Pacific northwest
                  Local Time:
                  2:51 PM
                  negative! each cylinder, including #1, travels thru TDC twice on a 4 stroke internal combustion engine. That means the crank spins two complete revolutions for every cycle of stroke events. So in short, when the timing mark on the dampener lines up with the timing mark on the timing cover it could happen at two distinctly different times, TDC on the compression stroke OR TDC on the exhaust stroke. Not to confuse you more, but that also happens on #6 cylinder only it's vice versa from whatever stroke #1 is on.
                • WSUTARD
                  592
                  73
                  Jul 13, 2016
                  Seattle, WA
                  Local Time:
                  2:51 PM
                  Got it.
                • mario03srt
                  432
                  83
                  Apr 12, 2015
                  Amelia Oh
                  Local Time:
                  5:51 PM
                  WSU,
                  Every other 360 rotation it is at TDC.
                  Pull the #1 plug and verify that the piston at the top. Its not easy to see so use a long stick or screwdriver to verify. Or as others will suggest keep your finger over the opening and when air is pushed against and pssst past you finger it is on the compression stroke. Tough to do solo though!
                  Marion
                • nm9stheham
                  7,996
                  1207
                  Dec 20, 2013
                  Waynesboro, VA
                  Local Time:
                  5:51 PM
                  No, EVERY 360 degrees, it is at TDC. Every other 360 degrees, it is at TDC AND the cam is set for it to fire.
                  • Agree Agree x 1
                  • nm9stheham
                    7,996
                    1207
                    Dec 20, 2013
                    Waynesboro, VA
                    Local Time:
                    5:51 PM
                    On one rotation, when the 0 mark on the damper is lined up (with the 0 mark on the timing cover), #1 is ready to fire. After the next full rotation, when the 0 mark on the damper lines up, #6 is ready to fire. And so it alternates back and forth between #1 and #6 being ready to fire after each full rotation aligns the 0 damper 0 mark with the 0 mark on the timing cover.
                    That is why you have to determine if #1 or #6 is ready to fire by looking at the valve positions of #1 and #6 when the damper 0 mark is lined up. ONLY after you have determined if it is #1 or #6 ready to fire, can you properly line up the distributor rotor. Go back to posts 6 and 16...(Lots of 1's and 6's here LOL)
                    • Agree Agree x 1
                    • 73Swinger18
                      73Swinger18 ✱ⓈⓌⒾⓃⒼⒺⓇ
                      576
                      204
                      Aug 15, 2016
                      Camarillo, CA
                      View My Photos
                      Local Time:
                      2:51 PM
                      Have your buddy watching the engine tell you if he hears a weird clicking noise instead of filming the destruction of the engine...
                      • Like Like x 4
                      • Agree Agree x 1
                      • WSUTARD
                        592
                        73
                        Jul 13, 2016
                        Seattle, WA
                        Local Time:
                        2:51 PM
                        What the hell? Don't video, check!
                      • WSUTARD
                        592
                        73
                        Jul 13, 2016
                        Seattle, WA
                        Local Time:
                        2:51 PM
                        I get it now. Will make sure #1 is compression when I align the distributor.
                      • MrJLR
                        MrJLR Built, not bought FABO Gold Member
                        2,952
                        1294
                        May 14, 2015
                        Chino, California
                        View My Photos
                        Local Time:
                        2:51 PM
                        I 100% agree!
                        Jeff
                        • Agree Agree x 2
                        • Like Like x 1
                        • sireland67
                          sireland67 Well-Known Member
                          6,381
                          673
                          Oct 27, 2010
                          WV
                          Local Time:
                          5:51 PM
                          Never stick a screwdriver, or stick in a cylinder, use a common drinking straw, so no damage will occur.
                          • Agree Agree x 2
