evans68cuda
Hey guys, the cuda is ready for the road now! But before I take it out too far, I need to address the cooling system. I’ve got aluminum 26” radiator with a 17” clutch fan. I’ve let it sit for about 15-20 min running while I tuned on the carb and set the timing, and in that time got it to 210 degrees so I shut it off. This is going to be my daily and being in Santa Cruz county, traffic is a big concern so I would rather be safe than sorry here. I’ve heard good things about the ford contour dual fan setup and would really like to go that route, but not sure my alternator would be able to handle it. I’ve got the 70+ 60 Amp system and am using a 8 awg from the alternator directly to the battery, and the MAD bypass. Ive got an MSD 6al box, a heater, and plan on installing my 4 125 watt speakers. I plan on just running the speakers to the head unit and no subwoofer, so should be a low amp draw. My concern is will the 60 amp alternator be able to support the fans? No AC, elective fuel pump, or crazy sound system. I’ve read of guys on here running msd, electric fuel pumps and electric fans on the 60 amp alternator, but wasn’t sure of how many amps their fans pulled. I’ve heard the contour fans pull 40 amp at startup and go down from there. Thanks guys! Oh and it’s a mild 340 making 400 horsepower.
