Having trouble with my battery discharging in between uses. If I unhook the battery it holds voltage for over a week. If I leave it hooked up it seems to lose around half a volt a day. I assume something is pulling juice while the car isn’t running. Is there a common issue or a few typical places to check? Car is a 71 demon with stock wiring other than the ammeter bypass.
Thanks.
Thanks.
