There's not enough evidence that says holes did not come with the scoop option either! You were open to someone getting more info on the '72's and '73's from Galen Govier in a previous scoop thread. So in all fairness, I think we should agree that it's still up in the air, including the possibility that they may have come with and without the holes!
The burden of documented proof is on the "with holes" crowd because it's not common to find documentation that says what a car "didn't" have. However 7demon2 did post a parts page that listed the under-scoop grommets in '72 and '73 parts books. His quote was: "baffle a/scoop water (sports hood). part#2998881. it lists 2 being 1 for each hole. the third column is dart/demon. if you look down further in the same column near the bottom you can see the stripes listed and the scoop and scoop nuts to secure it on. the book is dated november 1972 in the right corner. now if the holes weren't being put in then why would they list the water baffels for it in the parts book for 72 demon and 73 dartsport? i still haven't been able to locate the article for this but i am still looking.....hope this helps shed some light.
While that is not "undeniable proof", because there probably have been parts listed that didn't actually make it into production models, it's a good start.
(The '71 Challenger T/A ad comes to mind but I don't know if that included actual parts.) There may have also been parts on production vehicles that weren't in the catalog. (i.e.: '71 spec 340's and/or parts in early '72 production models.)
I've been checking out later A-bodies for a long time and there would seem to be a lot of restored '72 Demons and '73 Dart Sports that would be "incorrect".
I also purchased a light blue hood with scoop, stripes, holes and grommets from an apparently unmolested 318 Dart Sport, which I still have.
So I'm not saying that a factory installed scoop could not have come without the holes. But everything I've seen, heard and learned makes for a comfortable umbrella over my "with holes" parade, even if the holes weren't in all of the scooped hoods ;) I'd put money on it. If we can only compile more info.
