B3422w5
Hello FABO members. I'm looking for some opinions on the drivetrain for my '72 Scamp. Looking to run 7.30s-7.50s in the 1/8 and still go to the occasional cruise night. But the car will see mostly track but only be on the street every once and a while. Here's What I'm thinking. Feel free to comment and make suggestions.
360 block bored .030 over with kb107 pistons
Holley strip dominator intake with 750 carb
Edelbrock Performer RPM 63cc heads
1.5 roller rockers
Stock crank and Rods with ARP Bolts (not looking to go stroker at the moment)
COMP XE294H Cam
727 with manual valve body, low first gear set, race clutches,etc
4300-4500 stall
8 3/4 Sure Grip with 4.30 Gears (debating 4.56s)
28x10x15 slick on 15x10 Weld Prostars (car has already been mini tubbed and springs relocated 4 inches)
Super Stock Springs
Adjustable shocks in rear
Car has disc brakes, and will have no back seat, 2 Kirkey racing seats and mild steel 8 point cage.
Look forward to input! Thanks in advance
You wont need the 4.56 gears with a 28 inch tire and the stock rods
You also probably wont need 4.30’s either
I have a stock shortblock 360 with 28 inch tires, and mildly ported eddies and have seen nothing going to 4.30’s from 4.10’s except more rpm.
You are going to want a solid cam, not what you are considering.
Mine has touched 7 teens, usually 7.20’s.
