340doc
Just picked up a 340 air cleaner that needs a repaint. I was going to use black wrinkle paint from the auto parts store. Is this the way to go? If so any tips for a good finish? Thanks.
Man that looks great Joe! Didn't know this could be done. I can ck with my local powder coaters and see if they offer it. Did the baking damage the gasket in the lid?
Great job on that engine, looks great. Did you apply any heat to help it wrinkle?
Appreciate the info Joe.yea that gasket was removed before hand. can buy replacement gasket dirt cheap.. Mopar Air Cleaner Foam Seal Gasket NEW 440 426 413 400 383 361 340 DR045 | eBay
Great, thanks DicerUsed a spray bomb over primer, heat here is your friend. Sprayed evenly and then use a heat gun to get a even texture, looked factory.
Thanks for the reminder 65. I've heard many people on here compliment her work.Leanna @CudaChick1968 does great wrinkle coat finish work - she did 65dartcharger’s Award-winning 65 DartCharger’s wrinkle finish Commando valve covers.
