fishmarket
Installed radiator core support and new AMD inner fenders.
I scuffed the back of the inner fender with red scotch brite and used weld through primer on the areas that would be inaccessible after they were installed. I really hate the primer, it makes the welds really crappy. Even if you grind it off in the spots to be welded it still contaminates the weld. Lately I’ve just been using POR15 and grinding off where the weld will be.
