bobj
Looking for ac drain hose factory ac 74 duster
You should start a wanted thread. This isn't one.Looking for ac drain hose factory ac 74 duster
This is all I could find. Might try going straight to the Vans Auto web site to try to see if it's cheaper.
https://www.ebay.com/itm/Mopar-Heat...Duster&hash=item5dabbce6bf:g:xzcAAOSw07Be~NOt
Thank you I need hose that comes out of evaporator case under dash board
The one on eBay goes from firewall out the inside one had flange with 2 screws that attach to evaporator case under dashI am pretty sure that's it.
The hose Rusty linked to appears to be the evaporator drain hose for the factory air unit. What a/c unit do you have? The evap drain just needs a hose. The flat/flap end is to let water out and prevent contamination in. A piece of rubber hose the right diameter works fine. My underdash unit has that.Thank you I need hose that comes out of evaporator case under dash board
What's special about this hose?...
as in why can't you just go to Ace hardware and pull a couple feet of generic hose off of a real and plug it in?...
Bob, click on "reply" and then type your response under the quotation.
I would call that the improper size of generic hose LOL...The proper size generic hose is to big for the diameter of nipple in case
Hose is made with a inside diameter the size of a pencil lead to feet in diameter. I find it hard to believe you can't find a piece of hose to fit snugly over the evaporator case nipple.The proper size generic hose is to big for the diameter of nipple in case
That is a pretty obscure part and may be not reproduced. You might find one with a wanted ad.Looking for ac drain hose factory ac 74 duster
I'm sure someone can find a old crusty mildew ridden hose off of a Factory AC and sell it to you for 80 bucks LOL..
Where do you post wanted add?That is a pretty obscure part and may be not reproduced. You might find one with a wanted ad.
In the classified forums. You started this thread in the heating/ac forum. The classified forums are further down the page.
That would have been a nice picture to have in post one...
I looked for one for my ‘73 to no avail. I finally fixed my original with some pvc pipe, hose clamps, and a spark plug boot from an LS plug wire.Looking for ac drain hose factory ac 74 duster
Good enough to keep the water out of the floorboard. LolThat looks like a nice rig, I thought it was a repop part at first glance.
