dartfreak75
Restore it, Dont part it!
I see alot of people who bypass the factory ammeter. Is this necessary? What's wrong with the factory ammeter that ppl do this? I would like to keep all my original gauges working is it ok to use it?
Mines Bypassed And still hooked up! I ran my Alternator Feed wire to my Starter Relay first and then a piece of Fusible Link Wire to the
old spot for it on the Bulkhead. It would still show a Discharge thus Working... but it is no longer impeding the flow to charge my battery.
People disconnect them because they're probably rated for about 15Amps and we run 60Amp alternator's now, So...
I put a Volts Gauge on the Dash hooked to the Cig Lighter, I can Rely on that.
In this Pic it show's how I Also ran an 8gauge wire (fused at both ends) from the Alternator directly to the battery for charging.
I'm still running all my factory gauges with no issues for 48 years. Keep it factory, it's looks better in my opinion.I see alot of people who bypass the factory ammeter. Is this necessary? What's wrong with the factory ammeter that ppl do this? I would like to keep all my original gauges working is it ok to use it?
There is nothing wrong with ammeter. The reason people bypass the ammeter is the connectors in the bulkhead connecter. The terminals are relitively underrated for the loads they carry. That and 50 years of thermal cycle and corosion.What's wrong with the factory ammeter that ppl do this
I use one of these. It shows volts and then switches to amp draw of the item that is plugged in. My phone is usually plugged in laying on the seat.Running a volt gauge out of the lighter is a pretty slick idea.
I didn't actually... I tried it and it was Alway's On So, I hooked it to the Ign wire to the Ballast instead.Running a volt gauge out of the lighter is a pretty slick idea.
I unplug it and toss it in the console when I get to the show. It's nice that the cig. plugs have constant power. Damn phone always needs a charge.That's kinda cool......but it doesn't go well with the original style gauges. lol
That's interesting! How did you reroute the wiring around it?i kept mine. removed it, inspected the lugs and insulation and re-routed all the heavy load stuff away from it. headlights, A/C, ect on relays that don't go though it. this way it still works but it shouldn't melt down some day
I'm glad you brought up the alternator because that was part two of my question. How do you know the amps of the alternator? The alt I have is a aftermarket one I have no clue what the amp isMines Bypassed And still hooked up! I ran my Alternator Feed wire to my Starter Relay first and then a piece of Fusible Link Wire to the
What does crackback headlight update do?"Is it necessary to bypass?" My answer is "it depends". How "much" do you intend to run electrically? If not much more than what the factory ran, then you probably don't need to do the bypass. Like with Vixen, all her wiring is in really good shape. The only thing I have added electrically is @crackedback's headlight harness upgrade, the aftermarket radio, which has no external amp and all of the interior lights and the trunk light. That's probably gonna be "ALL" I run. It's just something you're gonna have to decide for yourself. There's nothing "wrong" with the factory system, as long as everything is in good shape. If you plan on some real electrical upgrades though, bypassing it might be a good idea. I'm not even running electronic ignition and plan not to, so what I have now electrically is all there is. That's just one old dude's opinion.
Yea it's a Reman one! I didnt see any kind of ratings on the boxThey are normally stamped into it somewhere.....however, that does not necessarily mean anything, as they have usually been rebuilt, regurgitated, remanufactured, or whatever, so the stamped rating might not mean a thing.
to start, for the headlights you can use @crackedback's kit that's pretty plug and play, or @slantsixdan also sells all the parts and you supply your own wire. i used dan's setup and it worked great. i went a little more extreme and cut out the stock fuse block and rerouted everything. so the ignition, dash lights, horn and tail lights are still off the ammeter, everything else is off the battery \ charging system.That's interesting! How did you reroute the wiring around it?
you can call the store and have them look it upYea it's a Reman one! I didnt see any kind of ratings on the box
I dont plan on adding anything. I have a bluetooth board that I installed into the factory radio and its wired into the factory plug in. All the Ignition and lights are factory. No radio amps or extra lighting.to start, for the headlights you can use @crackedback's kit that's pretty plug and play, or @slantsixdan also sells all the parts and you supply your own wire. i used dan's setup and it worked great. i went a little more extreme and cut out the stock fuse block and rerouted everything. so the ignition, dash lights, horn and tail lights are still off the ammeter, everything else is off the battery \ charging system.
what all are you going to add other than stock equipment?
I like the sounds of that. I always hated how dim my headlights wereIt removes the load from the headlight switch and gives the headlights full alternator voltage through relays. In short, it brightens the crap out of the headlights and only uses the headlight switch as a trigger, instead of carrying the whole load of the headlight circuit, which it barely did with the stock setup.
I kept mine, added a volt gauge too.I see alot of people who bypass the factory ammeter. Is this necessary? What's wrong with the factory ammeter that ppl do this? I would like to keep all my original gauges working is it ok to use it?
Yup.The amp meter is not really the weakest link. The two bulkhead connections that feed the amp meter are usually what goes first. In bypassing those connections, the amp meter gets bypassed a lot of the time. Lots of threads about it on here and lots of different opinions and solutions.
