megavites
so I've run into an issue of oil consumption and smoke on startup after sitting. Everything seems to point to valve seals. Unfortunately, I have 500 miles on a rebuild and the I'm not totally confident in the headwork. They came to me with different stem heights and I ended up with diff. push rod lengths and adj. rockers.
I'm trying to understand the diff. valve seals. The stock umbrella rubber seals I bought were not used by head rebuilder. He used a blue (Teflon?)with spring hold that I'm assuming is a positive seal style.
I'm looking at replacing the intake seals and assuming a good Vitron seal like: Hughes Engines
would work.
Am I on the right track?
would work.
