coronet69swede
Hi out there.
Am i the only one having problems with borgeson box with doug headers D453.
It is less room for the header after the change. much moore room to the frame.
I also had to move the pump plate so the pressure hose will fit. And make a new pressure hose. Did a simple mesure and lined them both up by the holes for the screw. the borgeson is 10mm or 3/8 closter to the head and the header dont fit in between.
