cookietruck
I just got a Lunati cam and I don't see where it tells me if there is advance ground into the cam.
They call for 104 ICL with a 110 LSA so they want 6*.
The cam card lists the grind number as TF62-TF62-10-A
Then below that the grind number is called out as 04-TF62-TF62-10-A01
Does anyone know if the 04 preceding the TF62 means it has 4* advance ground in??
