Uncle Ben
Active Member
Hey guys looking for some advice on what to do about my brakes dragging. Ive narrowed the issue down to the clutch pedal. Seems that when you have the clutch pressed And then step on the brakes, if you let off the brakes, the pedal stays in place, for the most part. However if you aren’t on the clutch it will return the brake pedal per normal. Kit is wilwood power disc brakes. Under column is completely stock. Any one experience this?
