TAK65
Did 63 come with dual circuit master cylinders?
No, I just thought that they probably will not notice the upgrade.
Yup.My thought is there would be no one who could tell or notice the difference but i'd bet it would brake belter.
And if they did where would you get them today?
Two ebay vendors seem to have them.And if they did where would you get them today?
That was really bad. I mean seriously. lolMaybe Finland?
Let me pose this question. Let's just say for a minute you get industrious. You swap over some early A body disc brakes, master cylinder and proportioning valve. IF an inspection discovers it, what's the worst they'll do? Fine you? One time? If not much, it might be worth it.Two ebay vendors seem to have them.
That makes zero sense since you're making the car safer for the road. Oh well.A fine would be just fine
..no, it will fail the inspection and the only way to pass is to convert back to drums. A guy I know just did that a few years back, had a nice VW van with historic plates, converted to front discs and then converted back to drums. So no way I'll risk that.
Well I am originally from Finland so I better look for them when I go back in the summerThat was really bad. I mean seriously. lol
Yes, you might find finned things in Finland. lolWell I am originally from Finland so I better look for them when I go back in the summer![]()
9 inch
finned drums 5 on 4 inch PCD
Repro Finned Rear Brake Drum, Spring, & Clip Set : SV1-VG FITS Chrysler Valiant | eBay
finned drums 5 on 4.5 inch PCD
Repro Finned Rear Brake Drum & Spring Set VH-CM FITS Chrysler Valiant | eBay
provided drum depth is ok these will fit. Mopar in stud spaceing and centre bore
9 incn US and canadian drums fit my aussie car so aussie drums should fit a US Canadian mexican derived car
i.e the stuff that ended up in spain as local production or CKD Kits via chrysler Europe in Belgium ie spanish dodge desoto fargo.
designed for Track Pack Pacer and Charger RT in Oz
part of the gear homologated for raceing in 1970-72
the best improvment to mopar brakeing in my view is disks on the front and work on bias, either narrower rear cylinders or an upgrade to later rear brakes to get rid of the 60s duo servo design.
taller tyres bigger rolling radius at the back also helps.
let the front disks do the job properly without having to back off becasue the rears locked up in an alarming way.
your experince may differ Bitumen/TarMac highway or Concrete highway tyres water and temperature play a part
Dave
As long as you have 3/4" or so between your current drum and wheel, you should have enough clearance.One more concern; does anyone KNOW for sure if the finned 9" front drum will fit in an early 13" rim? Not really into ordering another thing that does not fit.
So, you can convert to a dual master cylinder, but, you can't use a later better factory braking system? Yeah, that makes sense.....Yeah, basically. When you register a car here as a "historic vehicle" it has to be pretty much as it left the factory, or at least could have done. So as a Dart was available only with 9" drum brakes in 1963, that's what I'm stuck with. They also told me I have to get rid of the back seat belts which I just stuck under the seat and pulled them back again later. And I had to get a special certificate (and pay some extra, of course) to get an approval for 185R13 radial tyres as the only option in 1963 was 6.50-13 tyres.
The reason for "historic" registration is you only need an inspection every 5 years, no emissions regulations and the insurance is very cheap.
I found that the original 1963 13" wheels don't work with the '65 and newer 10" drums. The '65 and newer 13" wheels will work with the 10" drums though. The difference in the wheels is the stamping of the center hub part of the wheel. You can tell the difference easily by the slots in the wheel. Wide slots are the early version that don't work, the narrow slots are the later ones that do work. You might be able to grind on the wheels to get clearance, but, I never tried to do that and don't know if you can gain enough to make it work or not without compromising the integrity of the wheel.I think so too, but will a 10" drum fit in a 13" rim? They WILL check if the tire size matches the one on papers so I wouldn't dare putting on 14" wheels.
You might run into the same clearance problem that I mentioned when using early 13" wheels with the later 10" brakes. You would need to get outside measurements of both to compare and to see if you even have a chance at them working.One more concern; does anyone KNOW for sure if the finned 9" front drum will fit in an early 13" rim? Not really into ordering another thing that does not fit.
You're not allowed to do that either, I just took a risk assuming they'd be stupid enough not to notice.So, you can convert to a dual master cylinder, but, you can't use a later better factory braking system? Yeah, that makes sense.....
How about front drums for 9 inch ?
