Matt68
Cast date 9-10-68. VIN denotes it went into a 1969 Dart, maybe a GTS. VIN LM23P9B227962. If you own the car, you have first option to buy the motor. Motor is mostly there; main caps, crank, cam, incorrect “J” heads, no lifters, valves, pistons, rods or push rods. Correct intake and AVS carb. Stock distributor. Oil pan and pick up with windage tray. Walls are clean, no gouges. I will measure, but as I recall Std. Bore, so figure .020 over to clean it up. Located in North NJ. 07869.
$1,400/obo. Prefer local pick up.
