Damn, that's a beauty!Every time I pull out of the auto parts store parking lot this truck is sitting there. .... Near as I can tell it hasn't moved in a year
Holy smokes cooler then that down here.near 1am and it’s 82F outside. ‘Feels like’ is 87. Thankfully this is the end of this heat wave for us.
Good to hear from you, Stephen!Morning all. 2 Sundays to go. Got some good sunset picks though.View attachment 1715960751
What are we reading? Idlin in the driveway? Runnin down the road? A full throttle blast through all the gears?
Howdy Rob!Good to hear from you, Stephen!
Sup, Stephen?Howdy Rob!
Morning RayMorning
You need my Cleveland.Just working. Ready to be installing parts on the 68 Fairlane.
Mornin Ray.Morning Rob
Mornin Mitch.Good Morning Gang!!!
Then I'm guessing it's probably close. They look a little rich and would be, because the correct way to do a plug read is find a long stretch of road, do a WOT accel through all the gears, cut the ignition off, coast to a stop yank the plugs and read them. So I'm betting they would read just about right. It probably runs good, no?Hey Rob..
Should have clarified...
Street cruising... maybe 3,000 miles
I own about 700 miles of that. Country road cruising. 45 -55 mph.
Spit balling the rest. Car only had about 2,000 miles put on it in 14 years... might be a lot of idling given the rotted out mufflers I pulled
That's what she said.Morning guys...
That came quick
Then I'm guessing it's probably close. They look a little rich and would be, because the correct way to do a plug read is find a long stretch of road, do a WOT accel through all the gears, cut the ignition off, coast to a stop yank the plugs and read them. So I betting they would read just about right. It probably runs good, no?
What carburetor?It's OK... There's been a stronger gas smell under the hood after I shut down and will sometimes take a couple cranks to get going.
New cap, rotor and coil got rid of the hesitation and occasional stall on acceleration from a stop.
Picked up a rebuild kit for the carb... that's next
