You must first remove the 65 kickdown bracket. The only thing you need for the Street Demon carb is their 124007DEM stud. https://documents.holley.com/lit701rev10.pdf The stud is almost in the right position, only .12 off on the radius with the throttle shaft. Next you need the upper 340 rod and spring as shown in post #21. Then the rest of the linkage down to the kickdown lever on the trans. Or go with a cable setup from Bouchillon Performance Engineering. BPE TorqueFlite Kickdown Cable Kit - Bouchillon Performance Engineering
