Tell you what unless your a serious racer you do not need all the bells and whistles for maybe 1/10 of a second. Biggest thing is get the curve right for YOUR motor.
I tried one. It made my tachometer needle bounce around. I only installed it because it had a rev limiter.The one I installed recently has the revv limiter built in. I like that feature!
Yup and you can do that with a single point distributor!Tell you what unless your a serious racer you do not need all the bells and whistles for maybe 1/10 of a second. Biggest thing is get the curve right for YOUR motor.
So true its worth double posting!Biggest thing is get the curve right for YOUR motor.
I would like that, too. I've communicated with her before on Facebook and she's always been very responsive.I don't know the inner workings, but they are now digital to my understanding. I've linked this post to the new FBO owner in the hopes she responds and enlightens the group.
Hi Dave , good post . Do you know amplitude of GM pickup at some rpm and mopar stock pickup at some rpm ?quite amusing BUT
that top picture is of the guts of a jaguar I6 or V12 lucas igntion unit not an FBO . presume accidental attachment due to big HEI bit in middle of small icon of picture
Its a lucas AB14 unit with a radio interferance supressor (capacitor) and a zener diode in the top right to clamp back emf to 350 volts the white bit is just an insulated connection for all the wires held down with a plastic rivet. there aint nowt special in there
these used genuine GM and delco HEI modules which could only put up with 350V back emf off the primary hence the zener diode protection.
the lower picture is of an FBO unit.
there is no relationship between the two items. the FBO unit i dug all of the potting compound out off i think used descrete compontents and the usual big chunk of power transistor.
but never bothered to own one so don't know the full history, using HEI is a bit of a swizz if its true.
one is made from late 90s onwards by FBO
one made/assembled by lucas in the UK from the mid 70s to to mid 80s.
FBO uses magnetic pickup for timing only. the one i pulled apart in the 2000s was a robust version of the mopar set up designed for 12 volt use and no ballast with a low ohm primary coil other versions may exist.
AB14 and all HEI uses magnetic pickup for timing and magnetic pickup signal amplitude for dwell control. and a laminated iron core coil, 12 volt no ballast 0.5 or 0.6 ohm primary
a replacement AB14 is about $400 thats one expensive aluminium case.
i'm happy to repair burnt out AB14s for $250just send em to me... i'll pay the postage back
Dave
then we know dwell control rate from V/ rpm .
No need to reduce dwell until under ~ 3 k rpm to avoid coil overheat is why , and how they can eliminate ballast R So may do nothing till that area down ?
I thought chip in HEI looked at time between pulses not amplitude but either can work . But if amplitude , you might be screwed up with wring mopar vs GM pickup volts .
By the way HEI is a lot better conceptually than mopar , so those saying “ just a hei “ are leaving 1 k rpm on the table . Nothing wrong with early dual point either from old dodge v8 to 57 . more dwell , i think 55 back fits A block ( shaft length) .
Saw a dyno test where msd died on dyno 56 hemi , guy put dual point and ballast R he had on it exact same HP right to 6000. Nothing electronic to punt , 400 still in pocket too
The MSD blaster 2 is a cannister style coilKeep in mind that the max permissable dwell at high RPM isn't very much. At 3000 RPM on a V8, you have 5 milliseconds between spark events. If you give the coil a millisecond to discharge, you have 4 milliseconds for it to fire. Keeping the same 1:4 ratio between discharging and dwell would drop that to 2 milliseconds at 6000 RPM.
Plug in the numbers for an MSD Blaster 2 coil and aim for a max current of 6 amps as a somewhat conservative safe level of current, and you'll find it needs to dwell for 4.9 ms to reach that much current. That 2 ms time at high RPM would only reach about 2.7 ms. At low RPM there is enough time that you would want to stop the charging at a point that limits current. The just isn't enough time to reach high levels of current at high RPM, so at that point any dwell control is aimed at managing the ratio of discharge time to dwell.
I tend to agree with you. But this is a stock 318 so I’m not lighting off a cylinder dosed with methanol or anything. It runs much better and doesn’t kill coils. So I’m happy.I would be using the coil that provides the most spark energy, not the one that is easiest to mount.....
A spark in free air tells you nothing about the spark characteristics of that coil.
Plus, you don't have 12:1 compression. That's when you need a bunch more spark. The stock Mopar system is fine. Even in the upper compression ranges, just add a hotter ECU. Problem solved. I just don't have the hard on for the HEI a lot of guys do. It's just not necessary.I tend to agree with you. But this is a stock 318 so I’m not lighting off a cylinder dosed with methanol or anything. It runs much better and doesn’t kill coils. So I’m happy.
