[FOR SALE] 440 big block ICON pistons, 440Source rods, Hastings rings
MopaR&D
Nerd Member
Augusta, GA
Set of 8 forged ICON 9947 pistons for .030"-over 440 RB engine mounted with KB press-fit pins on new 440Source factory replacement (#200-1132) connecting rods. Comes with matching Hastings ductile moly ring set. Got these prepped by a reputable racing engine shop in CO for my 440 build but decided to go a different route. Looking for $850 OBO plus shipping. Located in Hephzibah, GA 30815.
Do you have the weights for the Piston Rod assemblies? I guess what I'm asking is was this a balance assembly?
I don't have the numbers unfortunately, they were balanced to the stock forged crankshaft I have but no material was removed from the pistons/rods, all the weight was removed from the crank counterweights.
If it helps, advertised piston weight is 686 grams and pin weight is 190 grams. Idk about the rods though.
I forgot I had weighed each of the pistons with pins before having them hung on the rods and wrote the weights on the tops of the pistons. They're all around 882g +/- 1g. I didn't look at every single one because they're each individually wrapped in quite a bit of shipping paper and didn't feel like unwrapping them all but I can if needed.
