[WANTED] 340 oil filter adapter for a 1964 plymouth Valiant. See pictures
64whiteghost
Rating - 0%
0   0   0
Hello guys.
Fellow members informed me that I will be needing this specific oil filter adapter for my build.
Does anybody have this filter adapter I circled in the picture below ?
I will buy it. Im In Los Angeles CA
FYI- you can use either the 63-66 cast iron or the aluminum that is not 90 degrees. Of the mounting bolt has the 4 holes in the same circle, get the newer style bolts with the holes off set. They are stronger.
Tried to PM, you but your inbox is full. I have what you need complete with all gaskets. Pm me
No personal information on open forums fellas. Way too many scammers watching.
Go to your conversation/ dm page , click the box to the right of each message you would like to delete. Scroll to the bottom of the page and click on the advertisement X to get rid of it, it is covering the delete function.
Go to where it says mark all conversations and click on that and then you can delete your conversations so you can accept or even send out PMs. As you won’t be able to send PMs also if you don’t clear your box out. Become a gold memeber and you can have basically unlimited messages.
