[WANTED] Wanted 62 to 65 Holley 1 Barrel Carb for early A body
davescuda
Cheshire, CT
Lets try this again
Wanted Holley 1 Barrel Carb for early A body 225 62 to 65
From working condition to rebuildable. I took my bowl off my carburetor Badly corroded inside.
Seeing what’s out here before I try to clean it.
I assume you want an early A carb for the rotating rod throttle assembly. I have one on a 66 Valiant that's the same thing, unless you specifically want 62-65 for some reason.
That is correct, I need the Rotating rod throttle. I have a few myself but none of the early ones.
The weather here should be decent tomorrow, enough to let me get some photos. I don't know much about the carb as it came on a parts car. I did drive it on the trailer and back off the trailer and then across the property once but other than that I have no idea what shape it's in. I would plan on doing a rebuild no matter what your goals are. Pics and info tomorrow if the weather cooperates.
I have this new carb for sale. It’s been in a box in my storage for some years. I took these pictures yesterday.
Any luck?
Yes, finally. I'll need pliers to get the air cleaner off, it got rusted threads. Here are photos. Shoot me a PM if you're interested.
