[FOR SALE] RB and B stroker stuff
ValiantS
Shelby, Michigan
I can do some 'packaging' with these parts and other unlisted associated parts not listed depending on your needs. I'm about 25miles North of Detroit, Michigan 48316.
1)Roller cam LSM 4/7 swap NEW 278/290 @ 050 .490/.480 lobe 112 lsa (.730"ish lift with 1.5 rocker)$450
2)Roller cam Lunati NEW 276/284 @ 050 .460 lobe (.690"ish lift with 1.5 rocker)$275
3)Billet solid flat tappet ISKY '590' 320 adv 280 @ 050 matching NEW lifters and NEW iwis roller chain SOLD AS KIT ONLY $350
4)"B" engine '451' reciprocating kit: Good std 440 crank core/NEW BME 6.76 rods/4.375" JE pistons with pins (good used) $1200
5)1971 440 block partial fill std bore, good used ALLOY caps, bushed/indexed lifter bores $850 (needs finish machining)
3)SOLD
Updated listing as things are flying off the shelves...act now!
do you know what the actual number is on the lunati cam I'm in central michigan
I've only done Postal Money Orders or on rare occasion, personal check(which take a few to validate funds)
Thanks. Any idea on shipping to 98532 for the Lunati cam? If you have package dimensions and weight I can get a quote. I have an account with UPS.
Because there's been some interest, I'll separate the rotating 'kit':
*Pistons/pins/rings $500
*BME rods $750
*steel 440 crank std/std $150
