Remember my electric problem last weekend? Finally got an electrician out this morning, it was arching, sparking, and tripping the breakers all morning so it became an emergency instead of the two week wait to fix.
Looks nasty.Remember my electric problem last weekend? Finally got an electrician out this morning, it was arching, sparking, and tripping the breakers all morning so it became an emergency instead of the two week wait to fix.
I got exposed to the shuttles when I lived out in the desert. We used to see them hauling the prototype around on the 747 tow truck once in a while. I think we were 60 miles from Edwards AFB? There is Federal controlled air space all over that neighborhood, Edwards, Ft Irwin, China Lake. We were in the approach pattern from Ft Irwin to Edwards. I worked on the launch complex at Vandenberg for 3 years.Nice! I was just wrapping up national space week that week with my Civil Air Patrol squadron, happened to wake up early and was flipping through channels when I caught it on CNN, they were covering the expected landing and it was missing at first. Civil air patrol in Texas and Louisiana was used to help find the wreckage. I know they found one body, not sure if they found the others or not
second it makes a SHHHHHHHHHHH sound almost like sandpaper.. if i rev it at all it sounds like marbles.. and i mean like 1500 not 4k..
Hope it's simple like a band or kickdown adjustment
Flex plate?naw..simple doesn't rattle like marbles.. i'll have to pull it, i triple checked everything building it.. so i dunno
Bollocksnaw..simple doesn't rattle like marbles.. i'll have to pull it, i triple checked everything building it.. so i dunno
No biggy... i don't have exhaust or anything in the way.. trans won't be too bad to pull.. I'm just annoyed that it didn't work perfect. Might do some upgrades while it's out.. B&M flexplate and bolt in sprag.. just dealing with the shift/park cable is a pain..Bollocks
i did it last time with a long seal pick through the hole.. guy on youtube has a great video showing that, but i will prolly drop the pan before the trans to see what's up and get as much fluid out as possible..Pushbutton?
I have the cables nailed... easy peas Just takes a lot of fluid. I got tired of jacking around trying to release the shift cable, so I drop the pan to remove and/or install.
What can a gift card to Carlisle be used on?Good Evening....I received a $100 gift card for Carlisle today as a retirement gift. I will never use it so does anyone want to make an offer? I will post this here in the coffee thread again in the morning. Just send a private message
Why do you need that though? i adjusted mine with the pan off and checked it lined up on the rooster comb on each gear
ahh.. i should read thatI use it to follow the TSM procedure... then double check visually.
Solidarity Brother! I just got home from coaching my youth trap team and mixed one up. If it tastes like a Cotton ball swab from the doctors office, did you mix it to strong? I am asking for a friend!Checking in wife is at a lawyer's monthly dinner get together. She paid for a year last summer and this is the first meeting she's made. I'm on my own at least for a few hours so can't get in too much trouble. I had leftovers (KC Strips) and a Fargo John Tito's and G2 Grape Zero...life is good!!
I remember that pix! I think that was the catalyst for the now never ending barrage of three pedal suggestions! Hah!
