Is there an adapter for the Mopar performance Engine air filter housing
Kipprc
PG County, Maryland
Is there an adapter for the Mopar performance Engine air filter housing? I want run the hose back to the engine air filter housing but I don't see anyway to attach the hose securely. If you have the cast Mopar Performance Engine air filter housing, how is yours setup?
this air cleaner i welded a right angle piece of tubing to the base for the breather closed system . you can get an insert 90 and a rubber bushing to work also , but ?
Could you post a few more pics? :rofl:
Like the way you have your aftermarket AC Compressor tucked in there. Not so in your face as the factory AC setups, bet it works better too.
sorry that car is with the friend that had me restro it for them , spent enough to buy a new car , but as my friends want that old looking cherry ride , with some getup n goooo .
