1970 Dart 340 fender tag decode help
66340SEDAN
FABO Member #3649
Minnesota
Help me out, I used to know most of them!
END
M43 N41 N42 R11 V5X Y05
V1X C55 G33 M21 M26
FE5 H6X9 TX9 502 186661
E55 D32 LM23HOR ######
1970 Dart 340, auto, buckets, disc brakes, FE5 red with black vynal top and black interior, stripe delete. Thanks! 8)
END
M43 N41 N42 R11 VX5 Y05
V1X C55 G33 M21 M26
You pretty well already know.C55 is buckets, M21 is chrome drip rail, M26 is another moulding, M43 may be also, N41 is duals, N42 is tips, R11 is AM radio, VX5 is the delete, Y05 is "sold car"
sorry, was from memory. Don't know where my book is
G33 L.H Chrome Remote Mirror
M26 Wheel Lip Mouldings
M43 Grille Trim Mouldings
probably V5X Which may be V8X
V5 = Side trim strip in Black
V8 = butt stripe Black
Windsor cars don't usually designate stripe delete.
V88 would be a stripe delete. My Dart is a Windsor car and it has the V88 code. But it will have a black stripe some day HAHA.
Yup, V5X was correct, I changed it. I feel this is a pretty rare car because of the "stripe delete" option, also has bucket seats with an auto shift on the column!
Did 1970 Dart 340 cars ever come with an hood insulation pad and the fresh air scoops? Mine had a hood pad at one time, it has all the metal clips in place and some small fragments of the pad behind them.
In my Chrysler option code book it say's.
V5-mouldings-protective vinyl insert body side
X-black
I haven't seen both together either. Often Windsor cars will call out J55 - Undercoat/Hoodpad on the broadcast, but pretty sure this is undercoating only on Swinger 340s. J54 can also refer to hood pad, and I think if it had this code, it may have been there.
Grant
