Sep 18, 2004 #1 1 17dartandbroke Well-Known Member Joined Jul 14, 2004 Messages 184 Reaction score 0 Location Luling, LA do i have to replace it now? any reasons that it would do this without it being messed with.
Sep 18, 2004 #2 AdamR Big Member Joined Dec 31, 1969 Messages 17,345 Reaction score 585 Location Bethel, CT I would replace it. I had one do the samething.
Sep 18, 2004 #3 onehellofadart Well-Known Member Joined May 23, 2004 Messages 3,588 Reaction score 5 Location Moonachie, N.J. Was it mounted horizontal or vertical ? Anyway replace it with the marine one. Same coil except filled with epoxy, can't , won't leak. Also withstands high vibration. It can be mounted in any possition
Sep 18, 2004 #4 1 17dartandbroke Well-Known Member Joined Jul 14, 2004 Messages 184 Reaction score 0 Location Luling, LA it was vertical. i will be getting a marine one soon then.
Sep 19, 2004 #5 onehellofadart Well-Known Member Joined May 23, 2004 Messages 3,588 Reaction score 5 Location Moonachie, N.J. I said marine ,I meant hi vibration. http://www.jegs.com//cgi-bin/ncommerce3/ProductDisplay?prrfnbr=15536&prmenbr=361
Sep 20, 2004 #6 cuda66273 Well-Known Member Joined May 22, 2004 Messages 253 Reaction score 30 Location Oregon Coils will leak if they get overheated, it boils the oil and as it expands it will break the seal. So why are you using a High Band coil? Are you running a CD ignition system, like an MSD or Hi-6?
Sep 21, 2004 #7 1 17dartandbroke Well-Known Member Joined Jul 14, 2004 Messages 184 Reaction score 0 Location Luling, LA msd 6al
Sep 21, 2004 #8 cuda66273 Well-Known Member Joined May 22, 2004 Messages 253 Reaction score 30 Location Oregon They work fine with a CD ignition system. You'll need to replace it I believe they run about $40.00 90 Day Warranty FBO Coil $40.00 2 year warranty )
