I need an opinion on this equipment
It doesn't say how there by. FYI, ADDCO make this for the MoPars and are OE suppliers for the company. I do not understand what the "U" bolts are for.
I think the U bolts are part of the link mount to the rear axle.
Well, that is what kind of threw me. I have not messed with aftermarket suspension much at all and the OE material doesn't use that. The end links to the axle and the end of the bars to the body is what I normally see.
Everything in the kit is made exactly like the addco from the looks of it. Not sure if it is but I don't think it makes much difference. Its a good price I would go for it. save yourself at least 100 bucks.
The axle mounting bracket for the kit sucks (addco and this one). I would weld it together if you can before they fall off like mine did or use a 3" exhaust clamp as your mount like I did. I might weld a bracket on eventually.
Let us know how they turn out. I was never impressed with the Addco bars I've seen in the past. Hopefully, these are a new and improved version.
