A body wheel and tire sizes.
AdamR
Big Member
Bethel, CT
Please post you wheel and tire combos.
Front
Rim width
Rim backspacing
Tire size
Rear
rim width
rim backspacing
tire size
leaf springs mods ?
mini tubbed?
1/4 panels sretch ?
Front
Rim width 15X5
Rim backspacing ?
Tire size 175/75/15
Rear
rim width 15x8.5"
rim backspacing 4-7/8"
tire size 325-50-15
leaf springs mods moved 3"
mini tubbed No
1/4 panels stretch no
Front
Rim width
Rim backspacing
Tire size
Rear
rim width ------------>8"
rim backspacing
tire size-------------->325x50x15
leaf springs mods ?->Offset hangers
mini tubbed?--------->No
1/4 panels sretch ?-->No
Woo Hoo :lol:
Front
Rim width 15X7
Rim backspacing 4.5
Tire size 215/60/15
Rear
rim width 15x8
rim backspacing 4.5
tire size 255-60-15
Rear fenders rolled for clearence. Tight fit but doesn't rub.
Front:
Rim Width 18X8
Rim Backspacing 5 3/4"
Tire size 245/40/18
Rear:
Rim Width 18X9
Rim Backspacing 5"
Tire Size 275/35/18
The only thing I did was cut the rear 1/4 pannel wheel well lip
Front:
Rim Width 14 x 7
Rim Backspacing 4"
Tire size G-60
Rear:
Rim Width 15 x 10
Rim Backspacing 5"
Tire Size 27.5x10.5x15
with room to spare
Front
Rim width I will fill in later
Rim backspacing
Tire size
Rear
rim width 15X10
rim backspacing 7 1/2
tire size 28x13.5x15 MT ET Street
leaf springs mods? springs moved into frame
mini tubbed? Yes, stock wells split, inner moved to frame
1/4 panels stretch? No, but lip rolled up
Rear (version II)
rim width 15X10
tire size 30x13.5x15 MT ET Street
mini tubbed? Yes, stock wells split, inner moved to frame, square off inner at front
1/4 panels stretch? Yes, lip rolled up, 1 1/2 inches removed at front
rear : 15X6 chrysler rally 235/70/R15
front: 14X6 chrysler rally 215/70/R14
70 Dart leafs moved in with 3" kit. No tubs but inside well hammered with 3lb mini sledge. Outside lip shaved. Wheel 8x15 with 5" backspace. 29.5x9x15 E.T. drag slick. Hooks so well it bogs the motor. Need more motor.
front
14x8 indy slotted mag 3.5 back spacing
215/60R14
Rear
14/8 indy slotted mag 3.5 back spacing
245/60R14
Mods
None yet
Front
Rim width
Rim backspacing
Tire size
Rear
rim width
rim backspacing
tire size
leaf springs mods ?
mini tubbed?
1/4 panels sretch ?
FRONT
15x7
4in backspacing
225x40/15
REAR
15x8
4.5 backspacing
275/60/15
Mods
SS springs but even without they would clear
B body rear and had same setup with A body 8 1/4
72 Duster
Rear
rim width ------------>10" centerlines
rim backspacing
tire size-------------->275x60x15 I did have 28 x15 the tire was 12inch wide
leaf springs mods ?->no
This thread needs pics. Some people say a tire fits as long as the body doesn't hit it.
Limit your suspension movement and get the body up and any width will fit as long as you don't mind the tires sticking out the side.
Front
Rim width - 17x8
Rim backspacing - 5.72
Tire size - 225/50-17
NOTE: running Alter-k-tion.....NON- stock suspension.
____________________________________________________________________________________________
Rear
rim width - 17x8
rim backspacing - 5.72
tire size - 275/50-17
leaf springs mods? - no leafs. Street-lynx (triangulated 4 link)rear suspension. lower bars in stock spring location.
mini tubbed? - NO
1/4 panels sretch ? - rusty but not modified. :)
Front:
Rim Width 18X8
Tire size 245/40/18
Rear:
Rim Width 18X9
Rim Backspacing 5"
Tire Size 275/35/18
Any problems on the front while cornering?
Front
Rim width 15x5
Rim backspacing 2 1/2
Tire size 215 60s
Rear
rim width 15x10
rim backspacing 5 1/4
tire size 255 x 50's
leaf springs mods ? SS (2 left springs)
mini tubbed? no
1/4 panels sretch ? no
1972 Duster
215/70/14s front 225/70/15s rear
Front
Rim width
Rim backspacing
Tire size
Rear
rim width
rim backspacing
tire size
leaf springs mods ?
mini tubbed?
1/4 panels sretch ?
I think the year and body style definitely needs to be part of this. A 63 Dart is far different than a 73 Dart Sport.
All these sizes are making me crazy. I have a swinger and moved my springs in under the frame. Currently I have a set of 15 x 8 with 4.5 back spacing with a meager225/70 but they are close to the wheel well lip. i roled them to be safe because it was super tight. I would like to run a 275 on there but I would have to really add to the back spacing to get them in there. How are you guys running a 275? Maybe I have a wider brake hub that I am not aware of because the 4.5 BS on that 225 70 I have is already slamming me to the wheel lip. Plenty of room to go back but it would leave me with no front space. suggestions?
