A body wheel and tire sizes.
66 Barracuda 273/auto, lowered 2 front, 3 rear
14x6 4 inch back space 235/60/14 BFGs front
14x7 4.25 back space 245/60/14 BFGs rear
No real issues, fronts barely rub ? at full lock
Front
Rim width
Rim backspacing
Tire size
Rear
rim width ------------>8"
rim backspacing
tire size-------------->325x50x15
leaf springs mods ?->Offset hangers
mini tubbed?--------->No
1/4 panels sretch ?-->No
Woo Hoo :lol:
I thought 9 inch rim was narrowest that a 325 50 15 can be mounted on. Do u have a picture? I am wondering because I also have 15x8 back rims and am interested in mt 325 50 15
Kind of an old thread, but since I like old, here goes..
18x8.75, 6.25" backspace, +35 offset wheels all around
245/40x18 BFG pro comp 2 front
255/40x18 BFG pro comp 2 rear
wheels weigh 21 lbs. each
no mini tub, no offset hangers. a little ball peen hammer action on rear inner wells. no rubs
Front - 18x9
BS - 6.38"
Tire - 255 40 - Michelin Super Sport
Rear - 18x9
BS - 6.0"
I'm trying to fit 17"x8" bullitts with 45 mm offset, which turns out to be about 6.25 backspacing, with not much luck so far.
In the front, I have issues with wheel fitting the rotor hub, but hopefully after new rotors that will be solved. Once I get the fronts on, I'm hoping the wheel/tire doesn't hit any of the suspension/steering components.
In the back, I have issues with the wheel hitting both the inner fender well and the leaf spring. Considering that Duster's have narrower track in the rear than the front, I had already been wanting to upgrade to a B-Body axle to even things out. I'm hoping that will solve my wheel fitment issues.
Currently, I have the following:
Weld Racing Drag Lites
Front: 15" with 165R15
Rear: 15" with 11.5"x28" Mickey Thompson ET Street DOT Drag
The backspacing on those Welds are unknown to me at this time, since I have not measured them. Once I get my Bullitts mounted, they're up for sale.
69 dart rear tire size im running bfg ta's 235/70/15 and they are tight ! one issue is sidewall clearance 4.5"backspace is what i have 5"would be better ! then tread to front wheelhouse is tight . overall its not bad just dont load the trunk or backseat and your golden !!
Put spacers in front of the front hangers to move the rear back slightly. however those tires won't grow? How close are they?
Spacers in rear or offset shackles.
Update on my set up
got fronts 155x60Rx15 BF Goodrich 15x4's on hotshot rims
backs are255x 60'sx15 M/T's on 15x8's 4.5 BS steel rims
all have been powder coated black[/Q
did you have to do any rear end mods for rear wheels and tires to fit?
