[FOR SALE] 9103S BB TQ carb for sale
4spdragtop
Ontario Parts Unknown
Hey another carb for sale I don't need. 9103S, which I believe is for a 400?? Another stamping on it has a number(either I or L)?? Then 39 7
Looks like the solenoid bracket was bent and solenoid went thru the phenolic spacer. I have solenoid, bracket can be straightened out.
Has the larger 2 1/4" secondaries.
$50 plus the ride from Ontario.
Thanks
Steve
Through the spacer or the carb bowl?
If it is through the bowl, the phenolic resin fuel bowl, the carb is worth parts.
Is this a parts carb?
There is only one secondary size. You can tell if it is an 800 or 850 by the primary size 1 3/8 = 800 and 1 1/2 = 850.
Looks like the application is 1977 400HP with an auto. It is listed as having 1 1/2 primaries which would indicate it is an 850.
