Offenhauser 360 Degree High Rise Intake #5764 for B Engine
JAS
Active Member
In the Free World
Anyone ever use the Offenhauser 360 Degree High Rise Intake #5764 for B Engine intake for their "mild" B motor street car?
My engine is stock with a small cam and looking for an intake and want something vintage for it, but want one that will give it extra H.P.
Car is E-body 68 383 Magnum, 323's, auto, stock converter
Been considering the Edelbrock DP4B and wondering how this one compares to that.
Any thoughts on it?
I haven't used that particular one, but offy makes a good intake... I would give it a try...
It is a single plane, but the way it is designed, it essentially has a huge plenum, which brings back a lot of streetability. So it sorta has the best of both worlds. Extended RPM use of a single plane and good streetability of a dual plane. Similar to the old Holley Street Dominator.
Sounds good, thanks. Trying to decide based on a cam and carb change. The car won't be drag raced, so max RPM isn't a concern. I hear the Performer doesn't give much over stock, but the Edelbrock DP4B has a "different runner" design that is more advantageous for performance. I have also read that the Offenhauser Equa-flow and low riser aren't good, but haven't seen any information on this split runner design high rise for Mopars.
Correct ^^
The Offenhauser 360* 'Equa-Flow' High Rise is a good older Aluminum Intake.
The castings are of high-quality, and the units are heavier than the current
{more porous castings}.
It looks like a Dual-Plane in appearance, but the Intake has an 'open plenum'
and works off the Single-Plane profile.
And, the 'Center-Divider' does provide for more low-end Torque and mid-range Power.
It still is a very good Street Intake Manifold.
They work surprisingly well, even with a 'stock' Carter {630 CFM} AVS Carburetor.
