[FOR SALE] left over parts, pulleys, brackets, etc.
diymirage
HP@idle > hondaHP@redline
michigan
all items located in Holland MI, 49424, O.B.O. and free pickup (buyer pays shipping)
(small black LA parts)
double groove water pump pulley, 2 7/8 inch deep
got this in a package deal, it is painted semi gloss black by previous owner
$15.00 plus shipping
single groove water pump pulley, 3 inches deep
sandblasted and painted satin black
2 piece/3 groove crank pulley
I removed this from a 75 360 that came from a motor home
not sure what to say about it, it consist of a 2 groove pulley and a single groove pulley placed inside of it
I sandblasted and painted it before I noticed it was a 2 piece set up so could be redone better.
I imagine this can be used a 2 groove pulley BUT the two groove are different diameter.
$25.00 plus shipping (for both parts)
alternator mount for A/C setup
could use a blast and paint
electronic distributor with cracked cap
was removed from same 75 360
the motor was said to be running when it was removed but I never got a change to see/hear it run for myself
there is a little up and down play on the shaft, none sideways
$20.00 plus shipping
727 transmission braces
sandblasted and painted flat black
I intended to re-use these but the wont fit with the headers on
$10.00 plus shipping
non roller timing set
comp cams 3203 http://www.summitracing.com/parts/cca-3203
came with my cam set but I installed a double roller instead
brand new in open box
$20.00 plus shipping PAYMENT RECIEVED
2 sets of 3 to 2.5 inch reducers
first set is made by dougs and is 5 inches long
3 bolt flange attached to the reducer
(these seem to be coated)
second set is made by flow tech and is 3.25 inches long
3 bolt flange slides over the reducer and clamps down when the bolts are tightened
raw steel it looks like
(slant six parts)
ignition coil
car was running and firing fine when removed
(bracket and coil wire included at no extra charge)
2 3/8 inch fan spacer
should work on a LA engine aswell
7 blade fan
steel blades
slip on yoke from a 904 transmission
I also have a steering wheel adapter
it does not have the horn set up but will allow you to install a grant steering wheel on an A body (as long as you don't need the horn function)
miscellaneous brackets
$5.00 a piece plus shipping
(the red one has an extra hole drilled in it, allowing it to function as a steering wheel puller)
pictures will be up as soon as the wifey puts her phone down for a minute
timing set is SOLD
hurry up people, these parts are going fast :)
triple groove crank pulley
and two pieces pulled apart
alternator mount for A/C equipped small block
electronic distributor with broken cap
small block to 727 braces
dougs reducers
flow tech reducers
/6 225 coil
2 3/8 fan spacer
and miscellaneous brackets
(the alternator bracket is the same one already shown)
shipping quotes send on the Dougs reducers and the steering wheel adapter
